January 24, 2006, 11:52 |
3-D Aerofoil
I have just completed a 2-D aerofoil in gambit and fluent, and want to proceed to 3-D but don't know where to start. I understand that 2-D is the basis but how do i construct the domain? Can anyone please help. Thank You
January 25, 2006, 00:54 |
Re: 3-D Aerofoil
I can give you a set of data points for a 3-D airfoil flow problem if you want. But this might take some time. I got this data from an extensive google search. Try it and leme know if you still need me.
January 27, 2006, 07:42 |
Re: 3-D Aerofoil
Ravi can i have the data, so i can try it and see if it helps. Thanks Fatou
January 25, 2006, 16:21 |
Re: 3-D Aerofoil
Hi. once you have constructed everything 2d in gambit (aerofoil, rectangular domain..etc), all you need to do is select your 2d faces and use the sweep volume tool to whatever depth you want. (do this for aerofoil and the enclosing box so you have 2 volumes).then you need to subtract the aerofoil volume from your larger volume to create the flow domain. hope this helps
February 1, 2006, 14:03 |
Re: 3-D Aerofoil
I am still struggling with the 3-D meshing, can anyone out there please help this is for my final year project and i still haven't got a clue what to do. Is there like a tutorial on the web??? Please help me
Resolving aerofoil tip curvature in CFX-mesh | Jenny | CFX | 4 | October 3, 2007 05:55 |
digitizing an aerofoil/ meshing problems | Simon | FLUENT | 2 | February 27, 2006 11:18 |
Fluttering or Vibrating aerofoil | Alan | FLUENT | 1 | January 13, 2006 03:06 |
Meshing an aerofoil with a plain flap | Fatou | FLUENT | 0 | November 15, 2005 14:24 |
2D Aerofoil Simulation | StudentAndrew | CFX | 10 | October 28, 2005 16:15 |
