overshooting/undershooting temperature
Old   February 10, 2006, 05:23
Default overshooting/undershooting temperature
manohar
hi guys,
i am simulating heat tranasfer over a disc brake with rotating frame of reference. here i am getting the following error in the interations
temperature limited to 1.000e+0 in 10000 cells (or) temperature limited to 5.000e+3 in 10000 cells
in almost alternatively those 2 errors are coming. i am very greatful if u can solve my problem.
thanks in advance
Old   February 10, 2006, 12:32
Default Re: overshooting/undershooting temperature
Evan Rosenbaum
You may just need to reduce your under-relaxations, particularly on energy.
Old   February 11, 2006, 00:28
manohar
thank you for ur response,
i've tried in that way also, but i unable to stop the same error
Old   February 13, 2006, 02:47
Kharicha
Is your grid boundary layer able to resolve the thermal boundary layer ?
Do you impose a flux or a temperature at the disc?
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
