Pressure outlet boundary condition
Old   March 6, 2006, 02:44
Default Pressure outlet boundary condition
Rizwan
with pressure outlet: wat should be the order of backflow conditions same as those as inlet or default?
Old   March 6, 2006, 07:07
Default Re: Pressure outlet boundary condition
Brian
If you're using pressure outlets, you should not be expecting backflow through this outlet - so the backflow conditions are needed mainly to prevent the computation being unrealistic or unstable partway through the convergence, when there may be local unsteadiness causing backflow. It is therefore important to choose appropriate (i.e. realistic) backflow conditions, so you should really be using values that are close to the flow that would be found there physically.
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Static pressure boundary condition at outlet jennz CFX 4 February 11, 2014 03:29
pressure outlet in boundary condition help afshinbr Main CFD Forum 1 May 9, 2010 13:01
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 10:36
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
