settign periodic boundary condition
Old   March 13, 2006, 00:55
Default settign periodic boundary condition
ayapan
hi i am trying to simulate 3d flow ower circular cylinder. while i am trying for periodic boundry meshing in gambit the error message shows like that, "There nust be one edge specified for each face loop".i think i am missing something. can anybody tell what is the wrong with me.
ps: i was able to do meshing (periodic) without any error by the same procedure in the recent past. bye Ayapan
Old   March 13, 2006, 03:08
Default Re: settign periodic boundary condition
Volker Pawlik
1. Try hard-linking the periodic surface meshes in GAMBIT and generate your volume mesh afterwards
2. Do not set the boundary to periodic in GAMBIT
3. Make them to wall with different names
4. export the mesh, read it into fluent
5. Check the rotation axis of your domain i.e. the first fluid or reference fluid zone under report/reference zone (GUI): It must be equal to your rotational periodic axis.
6. make the two walls of pt. 3 rotational periodic with /grid/modify-zones/make-periodic using the TUI
7. if the mesh was linked correctly in GAMBIT the default tolerance value should work otherwise increase it slightly.
Old   March 14, 2006, 02:55
Volker Pawlik
Old   March 14, 2006, 10:24
ayapan
hi Volker Pawlik,
first i thank you for your replies, sorry i forget to write some important points in first message.
i faced the problem while hard linking. i splitted my domain in to nine(9) parts. likewise i am getting rectangular prism with center subtracted by the cylinder. in that part the hard linking shows the error message."There nust be one edge specified for each face loop". i tried by splitting the the inner domain in to two and now its working fine. thakning you for you help bye Ayapan
periodic boundary condition in LES martor FLUENT 3 April 30, 2022 00:20
periodic boundary condition (translational) fluent 6.3 haihek FLUENT 3 January 22, 2014 04:10
Calculation of pressure gradient in periodic boundary condition ksaat FLUENT 7 May 16, 2011 03:59
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 08:39
