seprate space between two parallel plate
Old   October 8, 2015, 02:50
Default seprate space between two parallel plate
bahram
bahramah is on a distinguished road
I want to validate a paper that investigate flow between two parallel plates.
plates have 300mm length. external magnetic field applied to a face between 120mm and 180mm. how can I separate this face from main face and apply external magnetic field?
I can active MHD module and I know where to select external field but I can't separate denoted face.
please help me
bahramah is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Running parallel case after parallel meshing with snappyHexMesh? Adam Persson OpenFOAM Running, Solving & CFD 0 August 31, 2015 22:04
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 13:44
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 15:15
