Which caracter for comments in fluent's journal ?
Old   April 21, 2006, 04:43
Default Which caracter for comments in fluent's journal ?
Jeffrey
Hi !
I would like to put a comment in my fluent's journal. I tryied // and /* ... */ (like C/C++) but it does not work !
Old   April 21, 2006, 04:51
Default Re: Which caracter for comments in fluent's journa
mAx
hi, try ;
;;;;;;;;;;; ; this is a comment ;;;;;;;;;;;
Old   April 21, 2006, 05:02
Jeffrey
Thanks...
I tryied to scale my geometry, using this :
grid
scale
;x scale factor
0.001
;y scale factor
0.001
The problem is that he answer me that :
/grid> scale
x scale factor [1] ;x scale factor
0.001
y scale factor [1]
/grid> ;y scale factor
0.001
invalid command [0.001]
Do you have an idea about wht's wrong ? and how to put a comment before a command ? thanks
Old   April 21, 2006, 05:32
mAx
do you have blank lines between scale and the following line? When I try this:
grid/scale ;x scale factor 0.001 ;y scale factor 0.001
it runs perfectly and it returns me:
: grid/scale x scale factor [1] ;x scale factor 0.001 y scale factor [1] ;y scale factor 0.001
Old   April 21, 2006, 05:47
Jeffrey
It does not run perfectly because the scale factors are behind ";", and you don't obtain "0.001" but "1"...
Old   April 21, 2006, 05:57
mAx
i tested it it runs. I edit the file with Ultraedit, which is usefull when you are working with Xp & Unix OS (end lines must be in UNIX format) else you may become problems
gambit journal for run a journal? Ralf Schmidt FLUENT 3 May 25, 2010 14:41
Param. & calculus in Fluent's Journal: Possible ? Kiril FLUENT 0 August 24, 2006 09:12
Problems With Journal When Writing Forces To File Andrew FLUENT 2 September 23, 2005 02:12
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 07:25
