Refences values and Drag
Old   April 20, 2006, 09:51
Default Refences values and Drag
Franckk
Which area sould we write in the ref. values to calculate a bullet drag ?
for a basic calculus, I would take the cross sectional area.
But to be very accurate, should I take the : head surface (it's a smooth head, like a diabolo) + outline areas + cap area (botom, near the firing pin) ??
Old   April 21, 2006, 17:39
Default Re: Refences values and Drag
Gurkan
Fluent is actually giving the calculated force. So, it's a matter of preference to use any of the areas. If the coefficient is to be compared to some data, then the same reference values (area, velocity, density, etc) should be used.
note: Setting rho = 2 should give the drag force, itself.
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Correct values of drag but high values of lift. aamer Main CFD Forum 16 December 16, 2010 04:44
Oscillating Drag Values ziyasaydam STAR-CCM+ 1 November 1, 2010 17:42
Wing Drag Values Ed Reed FLUENT 1 November 16, 2004 16:30
Lift and drag values of NACA0015 Marat Hoshim Main CFD Forum 2 February 9, 2001 01:48
