Colanar edges & Vertices: GAMBIT Issue
Old   April 24, 2006, 12:03
Default Colanar edges & Vertices: GAMBIT Issue
Khan
Hello
I am facing problem in making a face over an airfoil. It is giving me error
" the vertices & edges must be coplanar"
Can anyone guide me towards the solution. its very URGENT.
Regards
Old   April 26, 2006, 04:23
Default Re: Colanar edges & Vertices: GAMBIT Issue
Ralf Schmidt
its a difficult error:
For a face, every vertice MUST be in a plane. There is NO distortion allowed.
So the sollution: check every vertice and create them again!
Sometimes, it is not possible to have them in a plane, so try this:
Lets say, you have a square plane, that is distorded around its diagonaly axis (one vertices is outside the plane).
Now, simply produce two faces that are triangles, using each 3 vertices (3 vertices are ALLWAYS in a certain plane).
Hope, it helps Ralf
Strange error in Gambit while meshing edges Ilu ANSYS Meshing & Geometry 1 July 16, 2010 08:17
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Point and click to *add* vertices in Gambit? AW FLUENT 5 October 5, 2007 13:26
Gambit Size functions issue jon FLUENT 1 December 13, 2006 10:39
Gambit IGES import numeration issue Nicolas Meynet FLUENT 1 October 7, 2006 12:44
