May 20, 2012, 22:33 |
Modelling solid within a fluid
Rep Power: 13 |
Hi everyone,
I'm just getting started with FLUENT 14.0 (and computer simulations of fluid flows in general) so I hope this isn't too stupid a question. I'm trying to model the situation of having a solid sphere inside a cylinder in which fluid flows, and analysing the subsequent heat transfer to the sphere. From what I understood, the way to do this is to create the cylinder, remove the sphere from the geometry using cut material, freeze the cylinder, and then add the sphere material back in. And then mesh, solve, etc. However, this doesn't seem to be working for me. The fluid flow solves fine but it doesn't seem to recognise the heat flow across the fluid/solid boundary. I've read through the manual and the forums but there doesn't seem to be much help on this particular issue. If anyone has any suggestions they would be greatly appreciated. Thanks in advance |
May 21, 2012, 01:19 |
Rep Power: 15 |
I think your way of creating geometry should work. Although I usually create cylinder > freeze> add sphere by slice material. Then in the bottom left that displays solid/fluid you may need to add the two into one part?
May 22, 2012, 10:29 |
Rep Power: 13 |
Hmmm alright I'll give that a shot, thanks for your help
boundary, geometry, heat |
Solid to Fluid Heat Transfer Modelling Problem | bortonj88 | Main CFD Forum | 3 | November 14, 2011 14:21 |
Solid Fluid Interface boundary problems | shankara.2 | ANSYS Meshing & Geometry | 0 | April 22, 2009 16:05 |
fluid structure interaction | taru agrawal | FLUENT | 4 | September 10, 2007 03:12 |
Modeling of solid domains in fluent, no fluid flow | Satish Perivilli | FLUENT | 2 | December 1, 2005 11:41 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
