Help with parallel UDFs needed
Old   June 6, 2006, 08:40
Default Help with parallel UDFs needed
Nico
I tried to write an UDF for a parellel calculation.
In that UDF is a loop over all cells and some cell values are written in an array (cell volume and fraction of second phase). My computer is fitted with two cores, so i started two node processes. The loop is working on all cells, as far as I see, and it accesses the data on node 0 and node 1, like expected.
After runnig over all cells the array is sent from nodes to host, using the FLUENT-macro 'node_to_host_real'.
The host receives only the part of data from node 0, the node 1 data is not passed to host. Looking in the manual, I found no hint about restictions of 'node_to_host'. Also, I found nothing about any special treatment of node 1.
How I can send data from all nodes (read: all cells in parrallel calculations) to the host? Any hints are wellcome,
N.
parallel (cluster vs local) and UDFs ehooi FLUENT 3 January 6, 2011 02:45
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 04:31
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 17:18
Help needed in Configuring Parallel Computing Hari FLUENT 2 January 11, 2008 04:05
UDFs Parallel Implementation Rules Greg Perkins FLUENT 0 February 4, 2001 05:59
