Fluent Computation
Old   July 10, 2006, 12:02
Default Fluent Computation
Vidya
I'm facing a sttrange problem- I have a 3d geometry which was meshed partially in Gambit and the remaining in TGrid. I'm trying to run a steady laminar flow case. I input a velocity of 0.175 m/s at the inlet and want to maintain the outlet at atmospheric pressure. These are the only Boundary consitions that I imposed. All the remaining faces are treated as WAll.
When I ran the case in Fluent, it just goes on computing and the solution never converged. I also tried reducing the Under- Relaxation factors, changed to second- order upwinding, etc. Nothing worked.
Another thing that I noted is that in the plot of residuals, continuity is staying put at 100% error. The X,Y,Z velocities appear to be converging (at least it looks so in the plot), but continuity just remains unchanged.
I just cannot understand the reasons for these problems. Any comments/ suggestions?
Thanks.
Old   July 10, 2006, 16:46
Default Re: Fluent Computation
V. Kumar
A few general tips:
Check your all boundary conditions carefully. Check you donot overspecify things e.g both velocity and pressure at a BC.
Check dimensions (units) of your domain as well if they are consistent.
Such a problem, you must get a converged solution if code is bug free ( I guess it is)
Old   July 10, 2006, 17:05
Vidya
I checked all the parameters. I input a steady velocity of 0.175 m/s at the inlet and the outlet is at atmospheric pressure. The grid was created in mm and I scaled it after importing into Fluent.
So what could be the problem? It goes on computing for days and finally hangs up because the memory ran out.
Thanks.
Old   July 12, 2006, 08:12
Dr. V. Kumar
I m quite certain that there is something wrong with your boundary conditions. You may do the following test:
Set reference pressure in your domain 0 Pa (everywhere and also as initial guess before simulation)
Now at outlet set the static pressure BC i.e. P_static = 0 Pa.
Your problem may be that at inlet you are specifying a velocity and at outlet you are specifying a pressure of 1 atm which does not allow the liquid to come out and therefore continuity is not fullfilled. For an in compresible flow in a CFD solver absolute pressure has no meaning. Only the relative pressure i.e. P - P_ref is what a code cares for. Where P is the pressure in a control volume and P_ref is the reference presure at some point in your domain. A person who has never written a CFD code, unfortunately, do not realize this problem.
Hope this helps.
VK
Old   July 12, 2006, 08:43
Vidya
I set up the initial test values that you suggested...... and that's what I did earlier too. But the same problem continues. I don't find any error, but the computation just keeps going on.
Thanks, VR
Old   July 12, 2006, 09:37
Dr. V. Kumar
In addition to initial test values you have to set reference and boundary pressure equal to 0. I hope you had also done this step.
Old   July 12, 2006, 09:51
Vidya
Yes, I did that too. Nothing happened even then.
Old   July 12, 2006, 22:09
Vidya
Would it help in any way if I specify pressure at both the inlet and outlet? Then I have a very small value (about 1mm Hg at the inlet). So I think velocity at the inlet and pressure at the outlet is the best possible combination. Or will specifying OUTFLOW at the outlet help?
Thanks, VR
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
