How to automate number-crunching in Fluent
Old   July 18, 2006, 15:18
Default How to automate number-crunching in Fluent
Pedro Romero
I am generating a lot of information with FLUENT using the same geometry and fluid. Basically, I just have to change four numbers to simulate another scenario (four inlet velocities as boundary conditions). However, I do not know yet how to do it automatically (I have to type in every new scenario) so that I can leave the computer run for a while and retrieve all the results after all the calculations were carried out. By now, I just want to be able to run and save each case, but if you can tell me too how to post-process it automatically, that would be better!!!
Regards,
Pedro R
Old   July 18, 2006, 15:54
Default Re: How to automate number-crunching in Fluent
jasond
The details will depend on exactly what you want to do, but you should look into the use of journal files. Pretty much anything that you do in the UI can be recorded and played back, including postprocessing. Since you can edit a journal file with a regular text editor, once you have the setup/calculation/postprocessing done once (and recorded in a journal file), you can do some cutting-and-pasting, change whatever you need to, and complete multiple runs without having to do anything manually.
Jason
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 14:39
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
how to change CFL number in FLUENT using command xiaofish FLUENT 0 November 11, 2007 21:55
Can Fluent deal with complex number? demigod FLUENT 2 June 27, 2005 03:53
