PLotting iso-surface in 3D
Old   July 18, 2006, 03:24
Default PLotting iso-surface in 3D
Cyril
I've got a "tube" in a half 3D configuration.
I would like to plot the velocity in the symetry plane (x-y), for a given X (vertical iso, at the end of the tube) to see the speed close and far from the tube.
But I don't know how to plot it just in the symetry plane... http://img92.imageshack.us/img92/7622/tubeuo7.png
Can anybody help me !!??
Many Thanks !
(I tryed to create an iso surface x=1,50m, and plot it like in 2D, but it does not work)
Old   July 18, 2006, 04:10
Default PLotting iso-surface in 3D URGENT, plz help !!
Cyril
The reason of this plot is that I want to see how far from the tube the turbulences become low (to check if my wings (that's a small rocket) are wide enough to get out of the turbulences area).
Many thks !!
Old   July 18, 2006, 06:49
Default Re: PLotting iso-surface in 3D URGENT, plz help !!
rom
Open surface->iso-surface. Choose "Grid..." from the first drop down panel and "x-coordiante" from the second drop down panel. Click "compute" to get the min/max values for x. Input the desired x-value in the iso-value line and click "create". This will create a new surface for postprocessing (display->contours ...).
RoM
Old   July 19, 2006, 04:21
Cyril
Thanks, but when I do this, Ive got a plane like this one : http://img141.imageshack.us/img141/27/tubetr1.png
And the result is not very good (very bad in fact) : http://img215.imageshack.us/img215/5...eresultgd7.png
What I want is to plot it only in the sym plane, like a 2D case...
Do you know how ??
Old   July 19, 2006, 06:55
rom
For xy plots you can use a line for postprocessing. The follwing picture shows a 3d nozzle an how create a line (surface->line/rake) aligned with the green area.
http://img144.imageshack.us/img144/2737/hc1ne9.jpg
And here is the resulting line and the velocity plot along this line.
http://img222.imageshack.us/img222/3522/hc2me9.jpg
Hope it helps, RoM.
Old   July 19, 2006, 07:39
Cyril
P.E.R.F.E.C.T.
Thanks
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
