July 27, 2006, 11:12 |
Initialization Problem...Please Help!!!
Hey all, I'm trying to model diffusion throught two zones with different properties. One problem Im having is initializing the concentrations differently for the different zones. I dont understand how the DEFINE_INIT macro works. How do I set up the loops over zones and cells to isolate each species?? Is this how the main logic of this macro works? PLEEASE HELP!!! Cheers
July 27, 2006, 13:23 |
Re: Initialization Problem...Please Help!!!
have you tried using solve->initilise->patch
July 28, 2006, 10:22 |
I think that will work. Thanks for the advice!
July 28, 2006, 11:17 |
OK I have gotten to the patch part, but now Fluent won't allow me to define the concentrations differently for my 2 zones. Once I "patch" a value in one zone, it automatically does it for the other zone. Do you know how to fix this? Cheers
July 28, 2006, 19:13 |
I'm not sure how its patching zones that you are not selecting. Try initilising the two concentrations to zero over the whole domain and then patch them to values in zones.
you can also setup user defined patching zones called registers using the adapt->region panel |
initialization problem in fluent | morteza08 | Main CFD Forum | 0 | January 17, 2011 12:04 |
Initialization problem when using Axisymmetry BC | Eduardo | FLUENT | 0 | August 4, 2008 09:23 |
coal combustion initialization problem | Chetan Prahsant | CFX | 1 | May 1, 2007 05:41 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
