Incresing trend of residuals
Old   July 30, 2006, 21:59
Default Incresing trend of residuals
Vidya
Hi all,
In my simulation, the solution is not converging at all and the residuals always show an incresing trend and go even up to 10e+12 and higher.
My geometry is complex and has sharp edges and curved surfaces. The flow is laminar, though. The density and viscosity of the fluid are 1050 kg/m3 and 0.004 kg/m-s respectively. Will a highly skewed geometry like mine induce turbulence with a fluid like the one I'm using? Assuming this, I also tried running the case with k-e and k-w models. I also trie the coupled solver.
However, nothing worked and my solution never converged. My inlet velocity is 0.175 m/s. I also tried reducing the under- relaxation factors, etc.
Can anyone tell me what might be messed up in my simulation?
Thanks a lot.
Old   August 13, 2006, 23:57
Default Re: Incresing trend of residuals
pavan
hi, In my opinion, you have to change the mesh. Create a fine mesh where ever you've curvatures. Try to run the laminar case again. I think it should work now.
all the best pavan
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 03:59
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 17:10
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
residuals Karl CFX 2 June 24, 2003 23:13
