September 6, 2006, 05:24 |
re:abt vof
hi, i want to do for a simple mesh, i specified one boundary as mas flow inlet, another as pressure outlet and remaining two as wall, and i tried to solve using vof, method by specifying mass flow rate, but i cannot able to get the result.can any body tell,is it possible to specify a mass flow rate using vof method. if we can specify mass flow rate, how can it be?
September 10, 2006, 04:43 |
Re: re:abt vof
if your flow is incompressible, since density is contant, use velocity inlet BC. hope this helps. i used VOF for oil water flows to track interface and it was helpful for me. Regards
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 20:47 |
vof + hydrostatic pressure | ariorus | FLUENT | 0 | August 7, 2009 10:57 |
ATTENTION!! Validty of Fluent's VOF?? | ozgur | FLUENT | 1 | February 18, 2004 11:59 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
