September 11, 2006, 07:57 |
Extracting 2d geometry from 3d in Gambit
Hi
I need to extract a 2D slice from a complex 3D geometry in Gambit. Any tips on the best way to do this would be greatly appreciated. Thanks, Mike |
September 11, 2006, 08:32 |
Re: Extracting 2d geometry from 3d in Gambit
cut your 3d-geometry with a plane (surface). The section will be your slice. Then delete all the volumes, BUT check that "lower Geometry" is NOT enabled. Then delete all the faces except your slice. That's it!
September 11, 2006, 10:24 |
Thanks mAx,
I tried this several times before asking the question but without success, however after persevering it appears to have worked! Thanks again, Mike |
Geometry of Tank and Rushton Turbine in Gambit | jawidnaik | ANSYS Meshing & Geometry | 1 | February 4, 2015 07:28 |
create turbine geometry with gambit | badlaine | ANSYS Meshing & Geometry | 2 | March 26, 2012 23:54 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
What can I employ to create geometry besides Gambit? | summer | ANSYS Meshing & Geometry | 2 | February 11, 2011 14:50 |
problem about Importing geometry in Gambit | Hua Gu | FLUENT | 3 | April 2, 2002 14:24 |
