Error due to y+ value
Old   November 7, 2006, 09:32
Default Error due to y+ value
Munni
Hi:
I am simulating flow of air in pipe (long pipe with lots of elbow, bends etc) by FLUENT. I am using standard k-e turbulent model with standard wall function. My questions are:
1. Should I check wall y+ or y* value?
2. Lets say the y+ value is in the limit 15-200. But according to the theory we know lower limit is 30. With this current simulation (i mean value 15) what kind of error (%) will be introduced to the pressure drop data? Will it be considerable or negligible?
3. Its a huge model (around 3 million cell) and I am afraid I cant refine the mesh anymore. What do you recommend from your experience?
Thank you guys. Munni
Old   November 8, 2006, 05:19
Default Re: Error due to y+ value
Ralf Schmidt
Hi!
1. YES! y+ is extreamly importand, if you want to report drag - wall sher stress is calculated using the wall low - and that dependes on the wall function!
2. I am not so sure about that...
3. Use boundary layer option. that will give you a small wall disdance, but enables one to have the next cell larger. That reduces the number of cells.
Ralf
