November 26, 2006, 02:43 |
viscose heating
hi, I am modelling high viscosity fluid flow in small canals. I am studing maximum temrature and heat generation this canals. but in position with maximum velocity( axis of canal) in near outlet, temprature is less inlet temprature. this is false. can you guid me?
November 29, 2006, 13:15 |
Re: viscose heating
Hi Mohammad
I did it like you , and I found this problem like you. I think you set the outlet temperature with CONSTANT temperature. Now, I found you must set a outlet temperature for file for a parabolic for outlet temperature by UDF. mail me if you can Mr. Nantaratn |
Induction heating of hollow cylinder | cfd.geek | FLUENT | 1 | August 12, 2022 16:38 |
Pressure variation in a heating channel | gRomK13 | Main CFD Forum | 0 | August 6, 2009 12:18 |
Lower heating value | Andrea | Siemens | 2 | July 30, 2007 07:19 |
heat transfer - heating element to air in FloWorks | Duncan Gravill | Main CFD Forum | 1 | March 28, 2007 20:16 |
Heating Element w/ Perpendicular Fins | Ryan | FLUENT | 1 | August 27, 2004 12:01 |
