problem with oscillating cylinder
Old   December 18, 2006, 04:06
Default problem with oscillating cylinder
ammi
problem with oscillating cylinder I'm trying to simulate piston oscillating in in cylinder(a compressor). I've met with some problems which i hope someone can help... my problem 2d axisymetric dynamic one. these are the steps i took: 1. Read in the mesh 2. Prepare the udf file given as #include "udf.h"DEFINE_CG_MOTION(vel_comp,dt,vel,omega,time ,dtime){real freq = 34.0;real w = 2.0 * M_PI * freq;real Xcomp = 0.004511;NV_S(vel, = ,0.0);NV_S(omega, = ,0.0);vel[0] = w * Xcomp * cos (w * time)} 3. Compile the source file , its ok. 4. gone to dynamic mesh - zones. Choose the remeshing and smoothing option I've selected piston with rigid body motion with the udf profile just compiled. Cylinder and axis as deforming one. Setted the value as in poppet valve example 5 )in BC condition where to set the velocity of wall (a udf function). ?????? Is it require. ? i am getting negative volume problem. how to solve ? from mesh motion review i got it is not remeshing plz reply ammi
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Lift Hysteresis problem in Oscillating Airfoil Farid CFX 3 March 29, 2012 05:52
Oscillating cylinder using icoFoam blowing up rieuk OpenFOAM Running, Solving & CFD 5 September 22, 2010 11:25
[Other] Shadow wall region problem amoolraina ANSYS Meshing & Geometry 0 July 25, 2010 21:17
flow around oscillating cylinder gs Main CFD Forum 0 May 31, 2004 06:34
