urgent help needed on dpm
Old   December 18, 2006, 05:46
Default urgent help needed on dpm
vaishali
In discrete phase model, is there any way to find the exact position at which particle is getting trapped? Thanks !
Old   December 18, 2006, 11:05
Default Re: urgent help needed on dpm
MM
YES! What you do is enable step-by-step report type and it will tell you position velocity, etc.
Old   December 18, 2006, 11:23
vaishali
Thank you very much for the response !! But step by step response will give the information about the particles present in the domain and not the particles which are trapped. I am interested in the position at which particles are getting trapped.
Old   December 18, 2006, 14:20
Jan
It is rare that you can find the solution to your problem at fluentusers, but in your case I think you can do it. At the fluentusers you can find a udf for counting wall hit, you can possible extend that to write the position. It is also described how to create a phs file which I think can solve your problem.
Wall function for DPM needed AMusteykis FLUENT 0 January 13, 2010 15:02
Urgent help needed with dpm analysis Esosa FLUENT 0 June 12, 2009 05:06
URGENT - DPM Macro for custom bc cfd-user FLUENT 2 July 21, 2008 11:26
Urgent help needed with spray injection nick Siemens 14 June 29, 2008 18:48
Help with DPM UDF for OUTPUT needed Zhengcai Ye FLUENT 0 January 5, 2004 16:58
