January 9, 2007, 08:05 |
turbulence
I want to plot rms velocity plots for turbulenct channel flow. At what part of the channel should i plot this data. I have been told to plot the data on a line cutting through the centre of the domain, is this correct??
January 9, 2007, 08:23 |
Re: turbulence
If you are using an straight channel with circular cross section, it's OK because the solution is axisimetric.
good luck |
January 9, 2007, 08:24 |
Re: turbulence
Its a straight rectangular section with periodic boundaries in stream and spanwise directions. Is that ok?
January 9, 2007, 09:17 |
Re: turbulence
David, I don't undestand the periodic boundary in spanwise direction. Is an open channel with cross flow?
Sorry, I was confused about you first question, because i was thinking about a circular straight close channel and to plot the rms velocity in a line inside a cross section. But I think you should plor the rms velocity in a cross section |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 04:30 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 17:15 |
