February 12, 2007, 15:57 |
VOF, specific zone
Hi, Anybody know how to use VOF model to track interface only one specific zone. For example, There are 5 zones in my model. But I just want to use VOF interface tracking for only one of them (4 other zones do not use VOF model at all). Can I do this and how to do? Give me a clue. Thanks a lot
February 12, 2007, 16:16 |
Re: VOF, specific zone
just patch the zones with single fluid that doesnt need to solve the vof. ultimately, vof will be solved for the zone where there are two fluids.
February 12, 2007, 16:24 |
First, thank for your quick answer. But the problem is that I set multiphase in all zones of domain, and I just want to use VOF for one zone, the other zone I don't care. So in this case, VOF will automatically be solved for all zones, this is a thing I don't want (for some reasons, if I track the other zones by VOF, it causes some serious errors).
February 12, 2007, 22:26 |
Dear Le, i think u can work out and see it the way I mentioned. Coz once u have patched a certain phase in part of ur domain, solving vof multiphase in that region would not affect the already existing values and hence the solution. the solver adjusts the remaining flow properties in the remaining part of domain and for the patched region u can even define the flow conditions. hope this helps, regards
February 14, 2007, 14:09 |
Thank you. I will think the way you describe
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
