modeling objects in room airflow
Old   February 17, 2007, 17:57
Default modeling objects in room airflow
ahmet
Hi all, I greatly appreciate if someone could help me with the following. I am trying to simulate airflow, using Gambit/Fluent, in a simple rectangular room with two inlets and one outlet on the ceiling. I have a table (which consists of three planes only, no closed volume), and a three dimensional closed-volume object inside the room. I used 'Wall' boundary condition for the room walls, 'Velocity inlet' and 'Outflow' for inlet and outlet. However, what shall be the boundary conditions for the objects (table and 3D object) in the room? Thanks much in advance. Ahmet
Old   February 21, 2007, 17:39
Default Re: modeling objects in room airflow
kk
should be walls. These objects are like the baffles in the pipes which I treated as walls.
Old   February 21, 2007, 20:41
ahmet
Thank you for your response, I have one more quick question.
How should I define the volume?
(Just pick the room boundries? Would that override the objects ?)
Thanks all in advance. Ahmet
Salome and Code Saturne simulation of simple room and objects cristian.ocnarescu Main CFD Forum 0 June 21, 2010 10:19
HVAC Modeling Humans in Room LilBort CFX 27 July 31, 2009 11:08
tutorial for airflow modelling in a room shahriel FLUENT 0 September 4, 2008 10:40
airflow modelling in a room shahriel FLUENT 3 September 4, 2008 10:34
Question, modeling airflow through radiator Roland CFX 6 August 7, 2006 06:25
