Saving velocity contours to a text file
Old   March 6, 2007, 16:24
Default Saving velocity contours to a text file
Craig Johansen
This should be an easy one. I can't seem to save a contour plot of velocity to a text file for later use in Tecplot.
When I go to the menu Display/Contours there is no Write option
When I save velocity data on a plane using XY Plot, the text file only has two columns. I need the text file to have three columns: x, y,and Velocity Magnitude.
When I use File/Write/Profile: The output data is not accepted by Tecplot
Thanks for the help
Craig
Old   March 6, 2007, 19:07
Default Re: Saving velocity contours to a text file
tim
choose File-> export... select the format data you want to save.
Tim
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
