Injection
Old   March 9, 2007, 03:52
Default Injection
Daniel
I am trying to model the erosion in a 90 degree elbow. However I am having difficulties with applying injections. When I set an injection I then iterate the programme, but when I go to Report - DPM - sample, FLUENT informs me that all of my particles are incomplete. What does this mean?
Please can you help,
Thank you Daniel
Old   March 9, 2007, 13:07
Default Re: Injection
Allan Walsh
When you graphically track the particles, what happens? Do they stop in the middle of the fluid domain?
You should be able to increase the number of time steps or increase the step length (in the model->DP set-up) to fix this.
Old   March 9, 2007, 13:15
Daniel
Hi Allan,
Thank you for your help. The particles do not even enter the flow for some reason. Do I have to set the solver to a unsteady time domain?
Thanks
Old   March 9, 2007, 16:12
kk
1.check you inlet 'escape' or 'reflect'? 2.do as Allan said, increase the steps.
Old   March 10, 2007, 01:58
SA
ll
surface injection or point injection? sukura_1984 FLUENT 0 September 2, 2009 09:26
Urgent help needed with spray injection nick Siemens 14 June 29, 2008 18:48
On DPM injection properties. akr FLUENT 4 October 23, 2006 10:54
DPM, UDF, Injection Type Zhang FLUENT 0 June 8, 2005 15:51
using injection file and parallel process Cindy Jones FLUENT 0 January 23, 2003 12:40
