Fan Computations
Old   April 27, 2007, 04:42
Default Fan Computations
Keen
I have been running MRF computations of a 2-bladed fan in a duct. The fluid is air. The Mach numbers relative to the blade are significant (i.e. 0.5-0.6) only in a small region in the vicinity of the blade tip.
I am unsure as to whether to specify constant density or ideal-gas model in the "Materials" menu.
Will selecting ideal gas compromise the accuracy in the regions (which form the bulk of the computational domain) of low Mach numbers?
Basically I would like to know which would be the more accurate of the two options: constant density or ideal gas?
Looking forward to advice.
Thanks in advance
K I Chan
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. saisanthoshm88 CFX 11 February 17, 2021 11:30
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 04:54
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Proper BCs for internal fan serezhkin CFX 3 July 28, 2010 10:04
Propeller Fan Curve Simulation Teng_YJ FLUENT 2 February 16, 2009 19:37
