Solver
Old   May 2, 2007, 14:06
Default Solver
nick
Hi, can I run a case using Pressure Based Solver, Cell Based Gradient Option and 1st order schemes for few iterations and then switch to the Density Based Solver, Node Based Gradient Option and 2nd order schemes ? I'm simulating high speed compressible flow, but if I use directly the Density/Node Option either the solution diverge or I have errors.
Thanks
Old   May 2, 2007, 15:44
Default Re: Solver
Phil
Why can't you just ask Fluent for afew iterations, change the options in the solution panel then continue?
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 09:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 09:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Development of a Low mach PISO solver nishant_hull OpenFOAM Programming & Development 0 August 25, 2009 12:48
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
