Going to buy RAM, suggestions?
Old   May 19, 2007, 09:18
Default Going to buy RAM, suggestions?
HSeldon
Hi folks: Iīm going to buy some RAM to my PC in order to run bigger cases. Since itīs a bit old I have DDR 400Mhz with an Athlon 64 socket 939. Regarding CFD applications, how important is the CAS latency? What other factors should I have to have in mind?
Thanks a lot.
Old   May 19, 2007, 13:11
Default Re: Going to buy RAM, suggestions?
farhat
Brand is very important, can go for CORSAIR or Kingston.
Old   May 20, 2007, 10:42
HSeldon
Yes, my idea was to buy a non-generic RAM. Probably Iīll go for the Corsair. And how important is the latency? Iīve been looking on the web and I discovered that the lowest latencies doesnīt give a lot more of performance, but I donīt know what happens with a CFD application. Here in Argentina the difference in the prices are considerable, so I would like to know if a CAS 2 REALLY worth the money over the CAS 2.5 or CAS 3 RAM. Thanks!
Old   May 21, 2007, 08:01
Thomas
With CAS 3 in one of my cases I obtain 26 s per iteration, with CAS 2.5 I obtain 25.7 s; compared to cpu fequency the influence of the cas is minimal: with A64 4200+ @ 230*11 I have 25.7 s, the same CPU @ 240*11 (an increase of about 100MHz) I obtain 24.7s. So: cas latency in itself doesn't give much more performance, but if u're looking for an OC system buy low latency or high frequency RAM. Let us know what u'll buy. Thomas
16 cores X5550, 48Gb RAM HPC purchase ACmate Hardware 6 May 28, 2010 01:00
Setting up a 32bits server with more than 4gb RAM HSeldon Main CFD Forum 4 February 21, 2008 11:45
using more than 2GB RAM on a windows PC Raju Main CFD Forum 10 October 22, 2006 03:29
Increasing RAM decreases CPU time!!! Melih GULEREN FLUENT 2 April 5, 2004 06:21
Can FLUENT run under Linux with 2 Gb of RAM? Paul Gregory FLUENT 0 February 13, 2001 20:10
