How to fix the temperature at the interface in VOF
Old   May 16, 2007, 04:52
Default How to fix the temperature at the interface in VOF
Was
Hi, when I am modelling the VOF, how can I fix the temperature at the interface of the two fluids? or how can I fix temperature throughtout the two fluids? Writing a UDF for volume fraction of 0.5? but how to specify it in fluent?
Any suggestion is appreciated.
Thanks.
Old   May 21, 2007, 13:43
Default Re: How to fix the temperature at the interface in
elemelek
You should first determine the cells where the 0.5 vol.frac. is located. Then you set the temperature at desired value.
Adaptative mesh around interface with VOF model baechtel FLUENT 0 May 12, 2009 01:35
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
VOF Lagrangian Interface Tracking Kam CFX 3 November 5, 2008 18:08
masse source at the interface in VOF model Marco FLUENT 0 September 26, 2007 05:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
