May 29, 2007, 04:43 |
XY Plots for different cases
Hi guys,
Is it possible to draw an xyplot mixing data for different cases? I mean, the same Y axis and the same x axis, but each curve for each case (for example, to contrast data about the pressure distribution for different velocities at the inlet). I know I can export to excel, but prefer fluent's plots. Greets |
May 29, 2007, 05:45 |
Re: XY Plots for different cases
To export curves to excel is no problem with the Write to File option in the plot menue. Do i understand it right that you want to plot results of two or more different .dat files in the same plotwindow? Maybe there is the chance with display / scene / overlay but i newer tryed that with different files. hope that helps Gernot
May 29, 2007, 06:54 |
Yes, I know how to write to file and work over excel. but I prefer fluent's plots and I wandered how to add curves (belonging to different case files) to the same plot. It would be very interesting, don't you think? in the same view, for example, skin friction coefficient in the same pipe and the same boundary conditions for different materials (water, oil, whatever...).
Regards |
May 29, 2007, 10:20 |
Write each plot to a seperate .xy file, then load them together at "Plot-> xy plot -> load files"
May 29, 2007, 14:50 |
Thanks man, I didn't think in that!
How to speed up the simulation of a large amount of similar steady state cases | tss | Main CFD Forum | 4 | November 5, 2010 14:36 |
CFD Validation Cases | doug | Main CFD Forum | 4 | January 11, 2010 19:28 |
Directory constructions of complex cases | 7islands | OpenFOAM | 2 | August 26, 2008 05:25 |
drawing of contour plots | chinthakindi | Main CFD Forum | 1 | April 27, 2004 04:33 |
Standard CFD test cases? | Damon Qualski | Main CFD Forum | 1 | April 10, 2003 14:10 |
