Prous Jump Help
Old   May 22, 2007, 15:59
Default Prous Jump Help
Derick
Guys:
I have a case where I have to use a gradutaed perforated plate in a duct. I am using gridgen to mesh. I give a boundary condition of"porous jump" for the required place and I export the case file. When I read in the case file, It does not give me an option to give multiple porosity values for different sections along the plate. How will I be able to do this?
Thanks a million
Derick.
Old   May 30, 2007, 17:44
Default Re: Prous Jump Help
Bob
Hi Derick, if you want to define multiple porosity for different section you have to define each section as a volume zone in the mesher. Name each section with an other name and import it to fluent. Then you can see in the boundary condition panel the volume zones and you can activate the porous zone model instead of the porous jump. The porous jump is only for thin parts like grids appropriate.
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
Pressure jump and momentum source Tanya FLUENT 1 June 4, 2009 15:22
Porous Jump Naresh FLUENT 0 April 25, 2007 15:36
porous jump boundary jump thread not handled hari FLUENT 0 March 4, 2006 02:24
Please Help ! Pressure Jump of Fan?? Boris FLUENT 0 January 28, 2003 20:26
