udf help
Old   June 11, 2007, 09:37
Default udf help
Rebecca
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
how could i resolve this problem, please help me.
Old   June 11, 2007, 13:49
Default Re: udf help
amir
hi when did u recive that?
Old   June 11, 2007, 16:51
magda
you should describe more. I think it's a common error message you can get all the time.
Old   June 12, 2007, 07:31
Rebecca
it happened when user defined sources were added in the fluent.
Old   June 12, 2007, 19:33
Tomasz Bednarz
Please check whether you have correct thread as a parameter when modifying your domain with source term
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
