can we know y plus in icem or gambit?
Old   June 18, 2007, 23:20
Default can we know y plus in icem or gambit?
ravi
Hi I wanted to know that, can we know y plus in advance (during grid generation)? Thanks
Old   June 19, 2007, 04:08
Default Re: can we know y plus in icem or gambit?
Anindya
NO. As y+ is function of parameters like the friction velocity (u*) which is dependent on the velocity you generally input in the solver part. The y+ value is not constant and will change with whatever boundary condition (velocity) you input in your solver and also varies with location.
Old   June 19, 2007, 04:20
Rams
you can calculate the y+ using the parameter u will be inputing in the solver, once u know the y+ value, make mesh such that the first node lies within this y+.
check out FLUENT documentation for y+ calculation
[ICEM] Gambit to Openfoam, Gambit to ICEM to Openfoam Rickard.Solsjo ANSYS Meshing & Geometry 7 November 30, 2011 10:20
Gambit extracting & ICEM hashem_1064 ANSYS Meshing & Geometry 2 October 22, 2009 02:19
Help: mesh conversion from Gambit to ICEM sarah_ron2002 FLUENT 2 April 5, 2008 01:53
How to export gambit model to ICEM Nirupama Main CFD Forum 1 October 28, 2006 13:06
Gambit or ICEM CFD Alan FLUENT 7 January 10, 2006 09:03
