June 16, 2007, 11:00 |
fluent background connection refused
Hi, I'm need to run Fluent in background using Linux cluster at four nodes.
I'm writting in shell: fluent 3d â€"t4 â€"g â€"cnf=/home…/fluent.hosts < roda > output2>> errolog & Fluent is started, but the nodes computes are refused. Could someone please suggest any alternate method to solve this problem? Thanks in advance. |
June 16, 2007, 13:23 |
Re: fluent background connection refused
I am not sure if Fluent sets the communicator by default. But from your shell command, you seem to be missing the -px option.
This is the script that I generally use (part of a PBS script). fluent 2ddp -t$ncpus -pnmpi -cnf=pnodes -g <run.inp> run.out Hope this helps. |
June 16, 2007, 13:27 |
"fluent 2ddp -t$ncpus -pnmpi -cnf=pnodes -g <run.inp>out"
June 17, 2007, 07:30 |
Vimal
Thank for help. Reginaldo |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
Rocks 5.4 Rsh Connection Refused for Fluent 6.3 | bucnikf90 | Hardware | 2 | March 29, 2012 16:24 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Runing the parallel version of Fluent in the background | Carolin Kosiol | FLUENT | 0 | June 26, 2000 06:09 |
