Floating point error
Old   August 7, 2007, 03:33
Default Floating point error
Ravi
i am simulating a supersonic flow (1.71 mach, laminar) in 2-D cavity. I used couple-implicit scheme.When i am using 1st order upwind, the vortices are not being captured int eh cavity nor the shocks. but when i go for 2nd order upwind, after some 5000 itterations, the message " temperature and pressure limited to ....." and then "divergence detected-temporarily reducing the CFL no..." and finally showing the error "Floating point error". Can sombody help me please....
Old   August 7, 2007, 06:47
Default Re: Floating point error
Joe
Look at the external flow supersonic tutorial.
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
