Why Contours not display in turb. flow over Cyl.? |
August 12, 2007, 07:23 |
Hi to all,
I am trying to model turbulent flow over cylinder at Re= 3900 in 2D. I found good drag coefficient (0.9) but the contours of stream function or velocity or pressure doesn't demonstrated the vortex shedding in the wake. For your information, I give the parameters used: 2D-unsteady-seregeted solver, K-ebsilon turbulence model, enhanced wall treatment, PISO, time step size=.01, max iter. per time step=20,BC-Velocity inlet-periodic-wall-pressure outlet etc. What's the wrong with me? Please help me if you have any experience. Mahbub |
August 12, 2007, 08:46 |
Re: Why Contours not display in turb. flow over Cy
Could be any number of things...
ke often over predicts the turbulent viscosity. You have to systematically evaluate all possible sources of disagreement. |
August 12, 2007, 11:10 |
try K-epsilon realizable model
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
contours display in post process | askriitr | FLUENT | 0 | July 1, 2009 10:55 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
