August 20, 2007, 21:09 |
Natural Turbulence Insensity
Just a quick question. Does anybody know of a typical turbulence intensity on the inlet of an external flow domain? I am modeling vehicle aerodynamics and I want to specify a more realistic boundary condition. Does anybody know of a reliable reference for natural turbulence intensities on roads etc? Best regards, Carlos. |
August 21, 2007, 02:55 |
Re: Natural Turbulence Insensity
Hi Carlos,
The way I see it, you have two major possible situations: - laminar, undisturbed flow in front of a car running at sufficient distance from other cars (hundreds of meters), when the level of turbulence intensity at inlet should be set, let's say to about 0.5-1%, and a turbulent viscosity ratio of 1; - turbulent flow in front of a car running in the wake of another, in which case, if you really want a very realistic model, you should use an interpolated profile for velocity and turbulent quantities obtained from another simulation (taken at a proper distance), or if the car is running in highway-like conditions, with cars in front and behind, at approx. equal distances, you could use a translationally periodic condition for the inlet-outlet pair. All the best, Razvan |
August 23, 2007, 11:12 |
Hi Razvan,
Many thanks for your suggestions. At present I am only interested in laminar flow in front of my vehicle. I just feel that having no turbulence intensity there is too clinical and unreal. Obviously there is an atmospheric boundary layer and low levels of turbulence in the air on roads. I will try your suggestion of 0.5-1%. I doubt it will change much of the solution but I am writing a paper and want to do it by the book. I cannot find much in the literature on natural turbulence intensity levels but if you know of one for your suggestion please let me know! Best wishes, Carlos. |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Natural convection with k-e turbulence model | hello | FLUENT | 2 | May 23, 2014 11:53 |
HELP!!! Natural convection with turbulence | leotsien | Main CFD Forum | 0 | October 29, 2010 03:23 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
