Gambit crashes when mesh volume Tet-TGrid
Old   September 14, 2007, 11:30
Default Gambit crashes when mesh volume Tet-TGrid
Cyril
Hi have a geometry like this http://img407.imageshack.us/img407/5809/meshiz9.jpg
I meshed the main faces around the profile and i want to mesh the volume using Tet/Hybrid - TGrid... Gambit simply crashes !!
Does anybody knows what's going on and what to do ?
Thanks!!
Cyril
Old   September 14, 2007, 14:16
Default Re: Gambit crashes when mesh volume Tet-TGrid
Allan Walsh
Which version of Gambit? I've had better luck with the stability of Tgrid meshing with V2.3 than with V2.2. That is, meshing operations that caused a crash in V2.2 were ok in V2.3, albeit with a lot of skewness. We've tried V2.4 a few times but as of yet haven't seen differences.
Old   September 15, 2007, 05:52
Cyril
I have Gambit 2.1.6 Does it means that there is no solution than having a new version ??
Is there any trick or anything else I could do to mesh my geometry...?
Old   September 17, 2007, 02:23
mAx
hi Cyril I assume it is a skewness problem Before Gambit crashes, you should receive a message, which means you have a skewness problem at face number xxx.... Go and observe this face, you should easy solve your problem (In you geometry, you just need to merge some faces) ;o)
Old   September 17, 2007, 03:18
Cyril
Great, I'll try that. Thanks.
P.S: I don't have time to read the message as Gambit crashes quickly..
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 02:22
[GAMBIT] Placing Specific Mesh Nodes in a Volume Mesh davisi ANSYS Meshing & Geometry 0 November 12, 2009 07:44
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
