3-D boundary layer
Old   September 19, 2007, 18:30
Default 3-D boundary layer
Cyril
I'm working on a fuselage, and I've set up a boundary layer around it:
The problem is that i've never done 3-D BL, and I'm not sure how to do it properly.. as you can see on the picture, the BL doesn't seem to go everywhere around the profile. Should I do the edges in the middle too?
Thanks!
Old   September 20, 2007, 01:26
Default Re: 3-D boundary layer
mAx
Hi Cyril, in 3d, forget the edges. You should pick all the surfaces surrounding your fuselage. Don't forget to enable the "Internal Continuity" in the BL options
Old   September 20, 2007, 08:45
Cyril
Thanks mAx..
I tried to swap the edges BL by a face BL and enabled the "internal continuity" option..... and I got an error message: "Currently, 3D boundary layers are limited to flat face groups with the same boundary layer on all faces. A discontinuity has been found where one face has a boundary layer and the adjacent one does not."
The problem comes from the edge in red on the picture. As you can see on it, the BL on face2 goes inside the profile which is strange... what do you think ?
Thanks!
Old   September 20, 2007, 09:02
mAx
you should attach your BL before you mesh your volume. Since your fuselage can be considered as several connected faces, I would create juste one BL in which attached faces are fuselage faces. Take care not including the symmetry faces in the BL. Once all connected surfaces are well attached, you should finally see the display of the BL just on the symetry plane, surrounding the outside contour of the fuselage on the symetry plane. I am not sure I've been clear
Old   September 20, 2007, 09:18
Cyril
Yeah, you're clear enough I just don't know what is "attach BL" and how to do it. (when I create a BL, I just clic on BL and then I put all the fuselage faces in the list..)
Old   September 20, 2007, 09:32
mAx
try to merge the 2 faces
Old   September 20, 2007, 13:36
Cyril
Good idea...... should have thought about that before.... !
Old   September 21, 2007, 08:42
Cyril
Yeah... that works !!
Many thanks mAx
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 07:47
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 14:21
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 14:11
3D Boundary Layer Mario FLUENT 0 February 17, 2009 03:40
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
