can't access face variables ...
Old   September 27, 2007, 22:32
Default can't access face variables ...
bart weisser
The following UDF will result in a segmentation fault. All it does is to go through all the faces and obtain a velocity component. The solution domain has been initialized prior to its execution. Interpreted UDF was used. Is there anything else I should be aware of?
<tt> #include "udf.h"#include "mem.h" DEFINE_ON_DEMAND(test){ Domain *d;Thread *t;face_t f;double u;
d = Get_Domain (1);
thread_loop_f (t, d) {begin_f_loop (f, t) {
u = C_U (f, t);
} end_f_loop (f, t);} /*thread_loop_f */} /* udf */ </tt>
Old   September 28, 2007, 06:52
Default Re: can't access face variables ...
max
What about using F_U instead of C_U?
Max
Old   September 28, 2007, 14:09
bart weisser
Shoot ... I meant to write <tt>F_U</tt> (not <tt>C_U</tt>). BW.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
