can't import T-grid mesh into ICEMCFD?
Old   September 29, 2007, 22:27
Default can't import T-grid mesh into ICEMCFD?
scott
recently i generate a hexa-core mesh with T-grid and go to the ICEMCFD to combine it with other parts,but unfortunately after the grid import the domain can't fulfill the mesh check,anybody know how to fix this issue pls tell me,thanks in advance.
procedure: ansa(surface mesh)->T-Grid(hexa-core volume mesh)->write fluent format(.msh file)->ICEMCFD V11.0(import the fluent mesh,change nothing)->export to fluent format mesh->error in fluent reading(Null Domain Pointer)
Old   September 30, 2007, 17:05
Default Re: can't import T-grid mesh into ICEMCFD?
red lemon
export hexcore mesh from TGrid as polyhedral type (TUI command) or convert using utility tpoly.
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 02:22
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
