September 29, 2007, 22:27 |
can't import T-grid mesh into ICEMCFD?
recently i generate a hexa-core mesh with T-grid and go to the ICEMCFD to combine it with other parts,but unfortunately after the grid import the domain can't fulfill the mesh check,anybody know how to fix this issue pls tell me,thanks in advance.
procedure: ansa(surface mesh)->T-Grid(hexa-core volume mesh)->write fluent format(.msh file)->ICEMCFD V11.0(import the fluent mesh,change nothing)->export to fluent format mesh->error in fluent reading(Null Domain Pointer) |
September 30, 2007, 17:05 |
Re: can't import T-grid mesh into ICEMCFD?
export hexcore mesh from TGrid as polyhedral type (TUI command) or convert using utility tpoly.
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
mesh missing after import in fluent | morteza08 | FLUENT | 0 | July 23, 2010 02:22 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
