October 4, 2007, 12:15 |
3D-wind turbine
Is it possible to use MRF in a zone which contain a wind turbine? The rotor of the wind turbine is model as a presure jump (Fan Model)? Thank you for helping me
Est-il possible d'utiliser le MRF dans une zone où un rotor de turbine éolienne est modélisé par un disque où une difference de pression est appliquée(Fan model)? Merci pour l'aide Khaled |
October 8, 2007, 06:10 |
Re: 3D-wind turbine
For turbine, you could analyze the turbine at stationary condition no moving at all, inlet boundary could far velocity inlet or pressure inlet with outlet as out flow or pressure outlet. After applied condition and iteration and ofcourse convergen solution, then u can pick the torsion distribution around blade, and from that you can find typically rpm of your turbine using corelation torsion to blade inertia.
I hope that can help |
April 22, 2010, 22:47 |
#3 | |
yashwant
thanks -- |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Wind Turbine - Rotation of the Baldes | moonomid | CFX | 32 | March 18, 2016 19:34 |
Ducted wind turbine (BC for the shroud) | Pepita | CFX | 4 | June 29, 2013 07:09 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 16:44 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 02:12 |
