GAMBIT internal error:face not found in the stack |
October 16, 2007, 09:02 |
Hey everyone,
I get a weird warning message in Gambit 2.3, when I export a mesh. It says: Warn: meshed entity face.183 was not found in the stack (internal error). And right after that, i get the usual message that says that the mesh was exported successfully. I tried to use the mesh in fluent 6.2 anyway, but I got a segmentation violation error when initializing the simulation. After performing a grid check, it showed inverted volumes, etc... not good So I relaunched Fluent, went through all the pre-prossecing steps again until initialization, performed a grid check after each successful step, and saved a back-up *.cas file each time. I then recieved a segmentation violation error just before initializing, when i was asking Fluent to compute the initial solution from the inlet. I launched Fluent one more time, tried to open the back-up *.cas, but then got a bunch of Segmentation Violation Errors during the opening... My guess is that everything is linked to the Gambit warning, but I can't see what's wrong in my model. Any clue? Thanks for reading! /JB |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Problems of running the parallel computations | lorraine | FLUENT | 17 | July 6, 2007 08:08 |
Gambit startup error: libXp.so.6 cannot be found | Patrice Guay | FLUENT | 5 | August 10, 2005 13:03 |
