Define wall using UDF
Old   October 24, 2007, 07:05
Default Define wall using UDF
Abhijit
Dear All,
I am trying to simulate a domain which resembles a two cylinder engine. Is it possible to define a wall using udf for specified time interval during the combustion cycle? It is required to close the ports of one cylinder while the other is operating or else there could be flow into the 1st cylinder. To avoid this phenomena I need to define wall or is there any other option. Please help...
Thanks...Abhijit
Old   October 24, 2007, 10:08
Default Re: Define wall using UDF
Abhijit
Dear All,
Kindly note during start of the solution the face is defined as interior and for few time steps it needs to be converted to wall.
Thanks...Abhijit
Old   October 24, 2007, 19:10
Venkatesh V
You can do that in Fluent using Events. Please look in the User GUide for help on Events.
Old   October 26, 2007, 10:16
Abhijit
Thanks for your reply & suggestion. I could find thread which suggested to define interface at the port face & delete the interface during running of solution at specified or required time step so that the cylinder remains disconneted.
Regards, Abhijit.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
How to use UDF to define a moving wall lingo FLUENT 2 April 23, 2004 02:38
How to use UDF to define a moving wall lingo FLUENT 4 April 14, 2004 04:14
