URGENT! PROB. WITH FLUENT 6.4 in DPM in PARALLEL
Old   January 10, 2008, 10:25
Default URGENT! PROB. WITH FLUENT 6.4 in DPM in PARALLEL
Aris Nikolopoulos
I cannot save .dat in parallel. Fluent crashes! I'm using Fluent 6.4 beta in Vista 64-bit with 8 computing nodes. The injection was created in Fluent 6.4.
Please help!!!
Old   January 10, 2008, 11:14
Default Re: URGENT! PROB. WITH FLUENT 6.4 in DPM in PARALL
James
It might have something to do with your DPM panel under the parallel option. Try changing it and see whether that would work.....it has to conform to the type of MPI you're using. I had a similar problem but was not even reading in my data file and apparently, the problem was from there.
Good luck!
Jimmy
Old   January 11, 2008, 05:14
Aris Nikolopoulos
Thank you a lot for your help! I did what you said,(unclick the DPM in weighting in partition and load balance menu) and there are ~50% chances of saving! I do not understand what is hapening... I'm using mpich2.
Old   January 11, 2008, 05:54
James
Just refer to the user manual for the fluent 6.4 and there should be some note on what to do if you are using fluent parallel for the DPM. I checked mine for the fluent fluent 6.3 and they suggested something there that i used to solve my problem.
Good luck!
Old   January 13, 2008, 17:36
Jan
Don't use fluent 6.4 beta with DPM !
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
parallel fluent setting in linux m2montazari FLUENT 3 October 10, 2011 16:42
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
Fluent dpm (unsteady) problem! Urgent! Aris Nikolopoulos FLUENT 0 January 17, 2008 07:54
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 08:52
