BC compatibility
Old   February 3, 2008, 21:20
Default BC compatibility
JG
Currently am modeling a section of duct with several features present within the flow stream including a porous screen. I want to mesh the inlet as a 'Mass Flow Inlet' BC so compressibility effects can be accounted for, and a 'Velocity Inlet' BC is not possible for this. The duct expels into the atmosphere in a plume. The outlet BC is modelled as a 'Pressure Outlet'. When solving I get a "Floating Point Error: Invalid Number" message. When going to a velocity inlet it will solve fine. Is there an incompatibilty problem present?
Old   February 4, 2008, 09:27
Default Re: BC compatibility
jesse
of course, boundary condition muss consist with physical property of the flow, mass flow in--mass flow out or velocity out pressure in--pressure out or velocity out
if you are given mass in, but pressure out, it is extremly difficult to resolve for pressure at inlet, or velocity at outlet;it is almost impossible, not that i know
Compatibility OpenFOAM 1.6 and 1.7.1 Ale_galleria OpenFOAM 2 September 20, 2010 09:14
compatibility fluent 12.1 with fluent 6.3 ak6g08 FLUENT 4 September 9, 2010 11:07
[ICEM] v10 and v11 compatibility problem Sofia ANSYS Meshing & Geometry 4 August 5, 2010 07:29
Compaq VF and Intel VC compatibility issues... Ford Prefect Main CFD Forum 0 May 5, 2005 23:58
Compatibility equations Stefan Maehlmann Main CFD Forum 0 January 22, 2001 03:39
