meshing jet case
Old   April 15, 2008, 15:15
Default meshing jet case
Jessica
I'm having trouble meshing a jet case that I'm working on. The problem is that I need to include a really large area around the jet (relative to the jet/nozzle size)- about 20D by 50-100 D. I was able to get a good mesh for one nozzle, but now I am usign several nozzles, which exacerbates the problem because I need to mesh the space between the nozzles and because the jet formed by the nozzles is larger. I need to have a fine mesh in the nozzles, a finer mesh in between, and a coarse mesh far away from the jet.
To make a long story short, I was wondering if anyone could suggest a way to mesh a case where both large and small geometries are present? The mesh needs to be very fine in some areas, but I would like it to be coarse in other ares to prevent the case from being too large. I am having trouble doing this using a structured mesh in Gambit.
Old   April 15, 2008, 17:31
Default Re: meshing jet case
AAA
Hi
Have you tried using Size Function? It works very well with such complex geomentries.
Also, you should consider sub-dividing the domain into smaller zones in order to have better control over the meshing procedure.
Regards
AAA
Hexa meshing or Tetra meshing??? NITIN DEWANGAN CFX 5 August 5, 2008 09:59
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 16:52
Problem seeing new case in case browser alan_fergus OpenFOAM Pre-Processing 9 June 22, 2006 03:46
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
