vof_model_grid refinement _urgent plz help
Old   May 13, 2008, 10:53
Default vof_model_grid refinement _urgent plz help
garima chaudhary
Dear all,
I am facing a great issue regarding simulating a rotating cylinder using vof method. I did for 6 different grid sizes for a domain of size 8cm*2cm. THe different no of cells taken are 1600,2560,6400,10000,25600,40000 for this domain size . I observe that the last two finest grids give me very different velocity profiles as compared to other grids, also i think its not realistic , i am not able to make out wats the issue bcoz as we go on refining the grid size the solution shud converge which is not happening.
i will be highly obliged if u kindly help me in resolving this issue , i need it urgently.
regards garima
Old   May 13, 2008, 15:46
Default Re: vof_model_grid refinement _urgent plz help
kk
what you want to study from this case?
Old   May 14, 2008, 00:45
garima chaudhary
i WANT TO STUDY VELOCITY PROFILES
Old   May 14, 2008, 01:35
kk
I mean do u have air-water flow or what type of flow regime you working with?
Old   May 14, 2008, 04:14
garima chaudhary
yes i AM TAKING an axisymmetric swirl case . my geometry consistes of a axisymmetric cylinder 8cm*2cm. the height of the cylinder is 8 cm and the radius is 2 cm.the cylinder is filled with water till a ht of 3 cm , the rest is air. at the top of the cylinder i hav taken pressure outlet boundary condition and the wall is rotaing at speed of 50 rad/sec. if u want i can send u cas n data file at ur id, but u need to send me ur id for that
Old   May 14, 2008, 15:35
m@rk@s
There may be several reason for not converging your solution, one may be turbulance modeling. Anyways which model you are using for Turbulance?
Old   May 15, 2008, 00:34
garima chaudhary
Dear Sir,
I am not involving any turbulence model bcoz the rotaional speed is 50rad/sec and hence its being assumed that there is no turbulence. can u plz help in this issue
Refinement Sara Siemens 0 August 5, 2008 12:18
meshing and geometry cleanup _urgent nag CFX 1 March 16, 2008 16:44
r-refinement ganesh Main CFD Forum 1 October 1, 2007 10:12
Refinement Gerrit FLUENT 1 July 9, 2007 07:20
refinement george Siemens 1 January 4, 2007 17:07
